keithm
- Mar 1, 2011
- 90 Ranger with
I've run into a slight snag, i'm attempting to use the fuel pump in the system which puta out about 40lbs, I ran that thru a single inletfuel filter with a dual outlet, one i returned to the tank, the other I ran thru a dial type adjustable regulator, there is pressure before the reg. but nothing on the out, I also tryed in on the reg before the filter, no change, pretty much tells me the reg is not working. My question is how much pressure ca a regulator handle going in. I was thinking that possibly the 40lb could be pusing the diaphram against the stop. Any ideas? Would a jdm with the vacumn set up work any better I'm not really familiar with the vacumn setup.
Thanks Keith
Thanks Keith
