I changed thatFuel filter? With the engine not running - turn the key to the run position for about 5 seconds. Then turn it off. Then back on. Do that about 3 times. Then check your fuel pressure. Each time you turn the key on, it will run the pump for 2 or 3 seconds. See if that gets the pressure any higher. Not sure if a 97 needs 35psi or more like 50-55psi. It changed somewhere around that time.
If the pressure doesn’t come up that way, then i would think it’s probably the pump or filter.
Otherwise, check pressure with the engine running. If low, maybe fuel pressure regulator which you haven’t mentioned testing or replacing.
I changed that all soFuel filter? With the engine not running - turn the key to the run position for about 5 seconds. Then turn it off. Then back on. Do that about 3 times. Then check your fuel pressure. Each time you turn the key on, it will run the pump for 2 or 3 seconds. See if that gets the pressure any higher. Not sure if a 97 needs 35psi or more like 50-55psi. It changed somewhere around that time.
SpecificationsEngine Displacement (Cubic Inches) 245 CID Type OHV (1990 – 2000) (VIN Code X)
SOHC (2001 – 2007) (VIN Code E)Bore x Stroke 3.95 x 3.31 inches Compression Ratio 9.0:1 Fuel System Sequential Fuel Injection Fuel Pressure 39 – 40 PSI (30 PSI @ idle) (OHV Engines)
64 – 75 PSI (SOHC Engines)Horsepower 160hp @ 4200 RPM (1990 – 2000)
207hp @ 5250 RPM (2001 – 2007)Torque 220 @ 2400 RPM (1990 – 2000)
238 @ 3000 RPM (2001 – 2007)Oil Pressure 40 – 60 PSI @ 2000 RPM
