Fuel Line
alpine67
Raleigh NC
Not sure if this is the right place to put this, but is there a difference in fuel line length between regular cab and extended cab Rangers? I'm doing a 5.0 swap from a 2000 Explorer into a 94 regular cab Ranger. Returnless vs return fuel line.
The line from the filter to the engine is the same, but from filter to tank is longer on extended cab
But shouldn't matter, you won't be using the return line, and will need to put a fitting on the engine end to match 5.0l connection
I think the 2000 explorer use an FPR(fuel pressure regulator) on the fuel rails IN line but can't remember
