Road Angels
First time for this one 99 ranger xl 2.5 pressure side fuel line coupling at the tank wont release, I can feel the tool open the garter spring up but the line wont release I have all the different ones plastic sleeve type, pliers type the alloy fancy one from snap on all open the spring but still wont come off. I even wraped some tape around the pipe piece so that it would push the tool open more when sliding under the connector so the sring would open more still no go, I have undone a lot of these types of fittings never a problem, did Ford change the tool thats required, the fitting also feels like it dose not slide up as far on the pipe as most do before you slip the unlook tool in to expand the spring, any Ideas
