nvcook42
- May 1, 2014
This is my first post, I am a complete noob when it comes to most of this, so please be patient with my ignorance.
I have a 87 Ford Ranger and 4 times now it has had the same problem. If I drive the truck for less than 10 min park go to a store for 10 min or so then come back out the truck will not start. It cranks just fine but everything points to a fuel issue. Once I tow the truck home it starts no problem. I can drive the truck to work and back everyday with no problems, 15-20 min commute.
Details:
V6 2.9L fuel injected engine, manual transmission
Fuel injector is new
Fuel pump relay was old and I have replaced it.
Truck is manual and won't start if I push it and pop the clutch.
If the truck is running it has no problems
Battery and alternator seem fine because the starter motor turns over well just sounds like no fuel is getting to the engine.
I have checked the inertia shutoff switch and its not that either.
Questions:
Could the fuel pump be going bad?
Its just seems odd to me that I don't have any issues for my daily commute but as soon as I run an errand to a store I get stuck.
If it is the fuel pump what can I check before I go and replace it?
How can I test the fuel pressure at the engine?
Any other suggestions or information you need from me?
Thanks for your help
Details:
Questions:
