2.3L ('83-'97) fuel line fittings.
Utah
Hello, i have an 1986 ranger with the 2.3L fuel injected. i was just wondering if anyone knew or can find out what kind of fitting ford used for the fuel pump and up onto the fuel rail?
The fuel rails usually had fittings similar to this.
2
The fuel lines at the pump usually used fittings like this.
"Ford EFI Fuel Rail" and "EFI Quick Disconnect (Push-On)", respectively. The former is different sizes for fuel and return; the latter can be different sizes by application, IIRC we use mostly 5/16" and some 3/8".
okay great thank you
when i was looking at the new fittings i want to get i found this guy and it is from what i believe it is the ford efi quick disconnect to 6an. i noticed that it is a different style and i was wondering if anyone knew if it worked for the quick disconnect.
