Fuel Issues part 2
1986RangerXL
Illinois
Okay, thought the truck was fully sorted out, took it to a scrapyard to drop off some metal, and it died. And it wouldn't start back up.
$60 tow and a fresh battery later, I turned the key and noticed.. fuel pump didn't prime. Test lights confirm no power to the high-pressure fuel pump. It is new. No fuses are blown, the inertia switch didn't go off.
I tried a spare pump, no difference.
I see the looms that come from the frame underneath the brake booster, but where do these pumps get their power?
Thanks
Fuel Pump Relay, on passenger inner fender, it will have a Green base, EEC relay has Brown base, WOT Relay(AC only) Black base
pink wire black stripe on the fenderwell going back. if it is stock. if the relay looks good, make sure its gettin power to there
could be a loose connection or green death corrosion connection on sender or in any of those plugs if it has power to the fenderwell...
I'm having same issue on resurrection project. Did you ever find solution?
