smccaffrey
- Oct 2, 2017
Hey All,
I am new to the group here.
Picked up a 1986 Ford Ranger for cheap and am trying to get it started. I bought it as a project truck. I am not much of a mechanic so I am using a few neighbors and the web to get some ideas. It cranks and will start with starter fluid. I don't think fuel is getting to injectors. I pressed the pressure relief valve on the fuel rail and just a drop of fuel came out then it was dry. I replaced the fuel pump relay, the fuel pump, and wired the inertia switch wires together. Still did not start. I bought a fuel filter and have since realized I have a fuel reservoir assembly, with the filter likely inside. I have a few options and there may be more. Replace the fuel reservoir assembly with one that contains a filter (more expensive), one that does not contain a filter (less expensive), take apart the existing assembly and replace the O ring and filter. Any thoughts on this would be much appreciated, also any mods that would make more sense. I would love to get this truck running. Trying to figure out what to test next. Any thoughts? Thanks!!!
