tinman_72
- Apr 14, 2008
- North Georgia
- State - Country
- GA - USA
- Drive
- 2WD
- 2.5 (4 Cylinder)
- Total Lift
- Factory
- Total Drop
- None
- Tire Size
- 255/60R15
- My credo
- RoHS compliant
I have a '93 5 speed with '98 2.5L motor.
How do I test the fuel injectors and computer? I believe one or the other is bad. I get a puff of white, gas scented smoke on startup. I get horrible mileage and the engine bogs whenever taking off.
The injectors are factory Ford injectors with ~150K miles. I have read that they can stick open. I also know that on other Ford vehicles there is a somewhat common issue with the computer causing one or more injectors to hang open. I don't know if it is common with Rangers or not.
I did a fuel pressure test a few months back and I am getting proper pressure but it builds slowly and does not hold when the engine is turned off. This leads me to think that it is an injector sticking open by itself. But I had the same issue before I swapped in the 2.5 leading me to think that it might be the computer.
I already tested the new FPR that I installed during the swap so I know that is not suspect.
TL;DR
How can I test to find out whether my injectors or computer are bad. (Or something else?)
TL;DR
