- Dec 5, 2007
- 4.0 V6
- Automatic
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- 31x10.5x15
- My credo
- Your character is demonstrated by your actions if you knew no one would ever discover them.
In a cold start scenario, what do the injectors do?
Does each squirt once into each cylinder just before TDC, then the engine keeps cranking until combustion occurs?
Thereafter, do the injectors squirt once per cycle?
Reason: I can't start my V-6. I pulled the fuel rail off the manifold and watched the injectors squirt as the engine was cranked over several revolutions--enough to get each cylinder to pass through TDC. Only two injectors (passenger side) squirted. Pressure in the fuel rail is proper.
Most sensors have been replaced, except knock-sensor. Will bad knock-sensor prevent engine from starting?
Crankshaft-position sensor is suspect also...if it is bad, is it true that the ECM/PCM will not know when/where to send fuel nor spark?
