footee
I have two different 92 Explorers. The first is pretty easy. The fuel guage stopped working on the previous owner. He said it worked sometimes then just quit altogether. My question, is it the unit in the tank that's faulty or in the cluster? It is a 4.0 auto just for reference.
My other Explorer, which is 4.0 5-speed, had been sitting without being started for about 8 months. The battery was dead so I tried to jump it but it just wouldn't jump with the battery so dead. I tried grounding the jumpers on the alternator and of course threw a little spark since I didn't disconnect it from the other truck. After that is when my issue started to occur though. The issue is, when engaging the key to the start position, nothing happens. There is power throughout the truck and the brake light comes on when you turn the key forward. I replaced the solenoid and that seemed to work but only for a few tries. Then it started doing it again. It will start by jumping the solenoid. Also, after running, the temp and fuel guages pegged out even though I know there isn't that much gas in it and I know the engine is not getting hot. My thoughts are, possible bad clutch safety switch, ignition switch, or some bad wiring. Anybody have any other ideas? It should be noted that it appears some mice decided to inhabit the engine compartment some. All that I've noticed is the heat pad around the HVAC is torn up with some droppings on top of it. I haven't noticed anything inside the truck itself.
