Fuel Gauge ???
1966stang
Need some help hopefully someone can answer this ? for me. I am putting a aftermarket fuel gauge in a 1988 ranger. The problem is I dont know what OHM gauge to buy.:icon_surprised: Can someone please help me??? Thank you
i am having trouble with my gauge also i have a 93 3.0 from i started stock ohm for my truck is Fuel sender is 145 ohms @ Full and 22.5 ohms at empty.
You can SHORT the Bk/Y and Y/W at the tank connector and see gage go to E (Must turn key to off, make the short, turn key to Run, see fuel gage reading go to E, turn key OFF immediately).
Re-reading your OP, I think your fuel tank sender FLOAT is perforated and filled with fuel. It's an $8 part from Ford, just a brass float.
dont know it is the same for yours.
thanks for the info nick
i appreciate your reply . my gas gauge works fine I am building a V-8 ranger and i am doing some modifications to the interior that will eliminate the factory fuel gauge therefore i am needing to buy a aftremarket gauge from summit.... ect. and they list different ohm gauges summit tech cannnot help me thought someone hear might know wich one to get agin thank you for your reply :icon_confused:
sorry for the trouble shooting info that was for me but from what i understand the factory sending unit is 145 ohms @ Full and 22.5 ohms at empty so if you are going to use the factory sending unit in the tank. the gauge you get will have to accomodate this. or whatever gauge you get you will have to get a sending unit for that gauge. spec tells you the ohms on the aftermarket gauges.
thank you nick
that will be a great help. thank you so much
