Fuel Filter
tedrisch
has anyone had problems with the rear line on the filter? i have a 99 3.0 and tried to get that off with the 5/16" disconnect wrench with no luck. I took it to two small places and they couldnt do it either. ended up gettin frustrated and taking it to Firestone and paid $89 bucks!!!! unbeleivable!!!!
No special tricks to it at all. Its just a typical fuel line dissconnect. Sometimes you have to spray them out with some brake cleaner and some compressed air just to clean them out.
its a pain in the ass and takes patience but thats about the only trick
I just did mine on my '99 too. I probably spent 8 hours on it and spent over $30 in tools plus $10 more on a tool I returned. I consider myself lucky I didn't damage anything.
The first tool was an OEM brand metal scissors-style, purchased at Autozone, which was so poorly made that it wouldn't close down on the filter inlet and fit under the shell of the coupler.
Second tool was a plastic collar type, purchased at NAPA. This one might have actually worked, but read on...
Third tool was another metal scissors-style, purchased at NAPA. I dressed up the welds on this one and it fit on the pipe and under the coupler shell. I may have felt the coupler release when I first pressed the tool in, but I'm not sure. The filter did NOT slide off easily. The coupler retention clips really had released at some point, but it took a lot of force and some twisting to pull apart.
After I got it apart I discovered the inside of the coupler shell had rusted and was an extremely tight fit on the filter pipe. Then, of course, the new one wouldn't just fit. I ended up pulling out two o-rings and taking a file to the inside of the coupler. Putting the o-rings back in was a challenge. In the end, I persevered.
So, don't feel too bad. I think barring problems like you and I apparently had, changing the filter is usually really easy.
BTW, the other important part about changing the filter is to depressurize the fuel system first. I disconnected the fuel pump cutoff switch below the glove compartment behind the carpet with the engine running. Once the engine stalls it's pretty much depressurized.
Take care,
Jim
thank you for all the responses. Next time I will try and be a little more patient. It is hard though while lying on your back with gasoline spewing all over the place!!
Did you purge the schrader valve first? Some fuel will come out regardless but not a whole lot. Thank God for lifts.:D
I have a 2005 I didnt look at it yet but on Michell on demand it said they are push type connetors. Does this mean no tool is needed?
i couldn't get the fuel lines off with the cheap autozone tool but i did get the lines to release with my fingers
yep theyre a pain took me about an hour to get mine off thats with a lift and 3 different kinds of tools once you get the tool in there and kinda feel it release you just pull till it comes off
Careful when taking them damn things off.. If you don't release the pressure the gasoline goes everywhere.. I got some squirting out once long ago.. I turned my head so it wouldn't get in my eyes.. IT GOT IN MY EAR! Much worse pain then the eye! Never, I'll say it again NEVER allow gasoline to get into your ear. Worst part of it is you can't hear yourself screaming!
Big JIm
Big Jim, I got the eyes years ago and learned ................. That's what dey make dem Safy Glass 4 :icon_twisted:................
Live an learn ..... Until I kill my self learning
