- Mar 25, 2011
- Galveston
- Automatic
when i changed the fuel filter on my 02 3.0l this past weekend I realized the new filter is a smooth cylinder, while the stock filter has a bolt and tab to locate it on the frame rail, or a built in bracket if you will. my 95 f-150 has a separate bracket for the filter that's mounted on the frame, I guess I assumed the ranger would be the same. I ended up cutting up the stock filter with a dremel, creating a holt in an arm of the bracket and ran a pipe band around the bracket and new filter. boot leg bracket accomplished.
TX Ranger
TX Ranger
