Nhaz
- Jan 29, 2009
- 1998 and a few
- Automatic
Okies. So as the title says the fuel economy on my truck is slowly getting worse. Im down to 400k on a tank and maybe slightly under.
I got out my obd1 module and looked for codes.
My tester showed as usual code 22 for a MAP sensor that doesn't exist on that truck and as far as I can tell never did.
I'm no expert on any of the obd systems so i re read the instruction manual for the OBD tester. it has 4 or 5 separate tests its capable of running. I was working my way through the various tests when i got to the KOER test.
The manual for the tester clearly says the module will first report how many cylinders the vehicle has by blinking the light on twice for 4 . 3 times for 6 . 4 for 8 and 5 for a 7,3 diesel.
The light blinked 2 times. and stopped. nothing else at all. waited the 20 seconds it says to wait plus another 30 for good measure.
I reran the test and got again 2 lights. Now i dunno about you but when I have a 4 liter 6 cylinder and the obd says theres a 4 cylinder I start scratching my head.
I stopped trying to complete this test and I am now at a loss at what to do next. Not to mention slightly confused =>
oh and BTW the engine runs fine lots of power and you can smell some unburnt fuel. Is it possible that a O2 sensor is misreporting? I mean i thought these things worked or didn't.
