fuel cell sending unit. how to up hook to factory gas gauge
Broncoman1532
Columbus, ohio
i have a bagged 95 ranger, removed old gas tank put fuel cell in i also have an inline fuel pump. i would like to use the factory gas gauge what wires to i need to hook up to the fuel cell
You need to make sure that the new sending unit has the right ohm out put as your old one.
Correct! Most fuel cells come with GM standard ohms and that is a different measurement of resistance than Fords.
Your ohm readings should be at empty 16 ohms and at full 158 ohms.
