Front wheels problems on a 91 ranger
mustangxlr8
I have a 91 two wheel drive ranger and i ran into a ditch and now my wheels stick out at the bottom and i have no clue how to fix them to give you an idea they set like this /--\ is it the suspension cause its not the ball joints i had them checked please someone help me :sad:
Get underneath it and look for something broken, or take several good pictures under there and post them up here...
i just looked under it there is a broke spring on the passenger side thats the only thing i see i dont think that would do it
That would have to be it. Think about it. Your spring holds the truck up, if it is broke, your truck would sit lower and since your front suspension isn't a dual wishbone style, your camber won't be right because of how it all pivots on one point. It's like how when you jack the truck up by the frame, your front tires go like this: \--/ but it's reverse because of the broken spring. Replace the springs and I bet you fix your problem as long as your ball joints are indeed fine.
you have a point i never gave it much thought it makes perfect sense ill try it and see and ill let you kno the turnout on this thanks 4 ure help:icon_thumby:
