front ttb sagging on my 95.. new coils?? spacers
4byRANGER
i need some softer but bigger coils than my superstiff 5.5's.. anyone have a set? or know a good direction to take this?
Skyjacker's #136 6" coils are a little softer than Superstiff's 5.5s, however they won't be taller. You can use a spacer under them no problem though (SJ's 8" coils might be TOO tall for your 5.5" brackets).
Other options might be looking into (straightaxle) F-150 or early bronco coils (or Jeep coils if your Ranger is a Reg Cab). You'll need to do some figuring in order to select a coil with the correct ride height if you go that route though.
national spring or deaver can also make you some springs if your willing to fork out the money for them.....I know national is right around the 300 mark
