front sway bar disco's
rickcdewitt
nor-cal
so i got the idea for some simple sway bar disconnects from another member of the ranger station(i forget,chime in if you know). the front is losing a couple inches of down travel from the factory setup pulling tight at the bottom of the travel. and has less flex than the back so its a good canidate for disco's. might as well try and see how much it rattles using the factory lower mount.i need to find bolts with no threads resting on the tabs to use but it works fine. the sway bar swings up out of the way where i secured it with a bungie cord.
That looks cool, i'm going to try that, is that a grade8 bolt? with the pin in it.
do you have the rear set up the same?:D
its metric,8.8 or 10.9. you have to get a different shaped bar for the rear and remount it for it to work like this. not the best way but it was free and it works.
