front shocks
Justin d
Tulsa OK
I have a 99 ranger I'm working on the shocks are completely blown i found some good used ones at the salvage. But they are in a 4 banger and mine is a v6 will 5.0 in the making. My question is with the 4 cylinder shocks hold up to the 5.0
[emoji52] I don't think they will if used . I just finished my 5.0 efi swap and the extra 100 or so pounds over the stock 4.0 engine has made it come down around 1 inch . Trans may weight more also since mine is aode . I have djm drop shocks on it right now and looking for a better shock .
I just wanna go fast [emoji48]
coils or torsion bars? they are different lengths. 2wd right?
FYI, coil IFS rangers can use front Crown Vic shocks with minor tweaking of the lower cross pin.
Perry
Perry
It cools and yes it's 2wd
Mines a 94 ibeam setup lowered . Hopefully we both get the info we need [emoji106]?
Mine is also aode
Perry
What year crown vics and can you explain tweaking needed
98.
the lower cross pin bolts are a slightly different width, I made a slight adjustment of where the bolt holes are, or size, or something. can't recall exactly what I did, but it was easy.
That makes things easier there are way more crown vics in the yards than rangers thanks
