ceraboy
- Feb 19, 2009
I have a 1987 Ranger Supercab 2WD that I recently swapped the 14" rims/wheels with 235/75-15. For the most part these fit just fine unless I hit a speed bump too hard and the front wheels rub in the well. I figured I would do just a 2" lift to bring the vehicle to the height of the 4WD factory units. I found a cheap pair of lift blocks at the wrecking yard and plan on installing them with spacers on the front end.
After looking in the tech library and browsing I have come up with two questions I cannot find a solid answer on. First of all with the rear lift blocks as shown in the tech library under lifting for cheap, what is the purpose of the angled lip that comes of the side of the block. I can see the alignment in the picture, but I cannot readily ascertain its purpose. Most aftermarket lift blocks are just a rectangular block.
Second, looking through this site I most commonly see that the lift ratio for the TTB suspension is about 1" spacer:1.5" lift, however, in my searches on this site and the web I have found some people state up to 1:3. I know with washers I could dial it in, but I have access to some scrap 3" round aluminum and a machine shop so I could punch these out myself, but I would like to get it close the first time. For people who have bought 2" lift/leveling spacers, how thick is the spacer not including the spring perch.
