Front Floorboards Wet
The Slider
Castroville, Texas
1972
I have noticed lately that my floorboards are always WET. It's not the heater core. Has anyone else ran into this before?? My rubber mats are growing mold on the bottom and my carpet stinks of mold. Maybe a plugged up drain? My AC drain is draining under the Bronco.
Thanks!
Charles
Well if it's never been clipped in the front end chances are it could be the door seals, or from the cowl vents in the by the windshield. Dirt and debris clog the drain holes and cause rust. I took the windshield wiper access plate off and clean mine out, it was full of years of crud. Also the sealant around the A/C inlet and heater lines may leak with the all the rain we've been having. 20 plus year old sealant tends to crack and you have to look for them. Hope that helps some.
Does it have a third tail light behind the cab over the bed ??? they can leak,,, and there is a deal on the passenger side behind the heater stuff that can stop up with leaves and stuff but it would only make passenger side wet
Oh! It's a Bronco II not a Ranger. I have cleaned out the cowl several times. How hard is it to clean the drains on the cowl?
Chaz.
They don't have drains holes, at least mine didn't that I noticed. It just angles down from the center to the ends on either side and drains out. Mine were clogged with lots of debris. I just removed the wiper access plate, center of firewall, used a shop vac and compressed air till I got it all out and could see light at each end.
Mine had tiny holes in the sealer in the drip rails. Water would eventually find it's way to the floorboards.
