front end
zebz21
well i finally got my new mounts and shackels in on my rear end and raised it up a few good inches.. I still notice that the front right tire is an inch or two lower. Could I have broke anything when i went in the ditch to cause that because i think thats what broke my leaf spring mounts.
Could have tweaked the frame. How hard did you go into the ditch and how deep was it? Got pictures?
Also, it could be your body mounts. If they were rotted then that corner of the cab might be sagging causing it too look like the tire is closer.
i hit it pretty good but it was in the snow so there was about 3 feet of cushioning.. ill try and get some pictures tho
