Front end Vibration Sovled
jburden78
St Catharines, Ontario
Hey, I've been reading posts and asking around for a while now about why there is sometimes a very noticeable vibration in the front end of my truck. It seemed like everyone I mentioned it to had a different solution. As it turns out, it was the hub assembly that I replaced that fixed the vibration.
For months, if I was driving short distances, everything was fine, but if I was driving for 30-40 minutes or more, ...if I hit a small or large bump, it would cause the whole cab to vibrate. ...Sometimes it would go away if you hit another bump, but not always??? ...but other times you could hit a bump and nothing happened! It was a little unpredictable at times.
From my own thoughts, and what people told me, it ranged from faulty cv joint, inner tie rod end, seized front axle, to worn sway bar bushings! I'm not saying none of these things if worn out wouldn't cause vibration, but it was a very time consuming process to get to the bottom of this.
So the purpose of this post is not to look for answers but to provide a possible solution for someone who may be trying to solve a similar mystery that I encountered.
Thanks for reading 8)
Why did you not check on the hub in the first place? A bad wheel bearing causes this issue as well. If you replace one you need to replace both of them, Bro. Did you check the wheel bearings and if they looked fine...did you clean and repack them? Lots of issues cause vibrations. Mostly worn parts or a badly broken part. Ball joints are a major cause of problems and the steering will reflect that. Bumps and dips as well cause issues with worn shocks or coil springs (on certain suspensions with coil springs).
Mine was solved by getting a new tire after popping mine. It wasn't balanced on wheel right so at 60+ it would shake violently. Hub assembly being damaged is dangerous. I almost lost it and would have badly damaged my front end I'd it didn't break on a slow road... All cause I slid on ice sideways into a curb with driver side front wheel.
I had already replaced both upper and lower ball joints, tires and outter tie rod ends previously, as well as the shocks and leafs. Visually, things looked fine, and I hadn't had this type of issue before, so it left me a little confused. I checked the obvious stuff, and I was surprised that it was the hub. ...I guess most others wouldn't be as surprised 8)
Anyway, problem solved. All is good now. Cheers :beer:
:icon_idea:
He didn't clean or repack his wheel bearings because he has a 98+ 4x4 which uses wheel hub assemblies. Take the old one out, put the new one in.
Ya btw, how much did your hub assembly run you? I had either cheapo for 150 or duralast one for 200 so I got duralast... It was in the middle price range and I haven't had a problem with duralast yet...
:icon_idea:
Hmmmm, the 98-02 Ford Ranger 4x4 has the 4W-ABS front hub wheel bearing assembly correct? I thought the bearings were replaceable. I could have sworn a buddy of mine replaced his last summer...maybe I misunderstood him.
:icon_confused::icon_confused:
Probably did. It comes as one complete assembly. Maybe it was 2wd and there's a difference? Idk. But mine was the 4wd 4 wheel abs one.
@bilzy7 > yeah, mine is the 4x4 abs type.
I tried to get aftermarket, but it wasn't fitting properly, so I got mine from ford. It was around $250. ...not too bad
Yeah 2wd are still the cone/cup roller bearings like everything a tad newer than a covered wagon.
Nope, my 98 and 99 were both RABS. The only way to replace the hub assembly is to take out the 3 bolts holding it on (and some other stuff in the way) and put a new one in. Basically, they aren't serviceable.
Blizy, OEM is Timken so that's what I went with when I did mine.
EDIT: Some are 4WABS, some are RABS.
Tanks for keeping us updated.
I know this is an old thread, but I recently got my '99 3.0 4x4 and am having the same exact issue. I have to ask: were there any symptoms of the hub assembly being bad? Mine has zero play in it, and spins quietly when lifted up. I have replaced the sway bar stabilizers (because they were cheap and easy to do) and the front shocks. Thanks for any info!
-Dave
AND..how do I check the hub assembly, other than the usual wheel bearing checks as above??
