Front end swap on my 94 mazda
jeddore, you blink and you will miss it
NEED HELP! Front end swap on my 94 mazda
hey, i got a 94 mazda 2wd and i wanna do a front end swap for a 4wd, question is, will a ranger front end fit on the mazda with out major changes, i need to know so i can start project redneck offroader THANKS:icon_welder:
The entire engine crossmember needs to be removed and swapped with one from a 4x4 truck before you can bolt any 4x4 components underneath the truck.
yes 83-97 4WD ranger, 91-94 exploder 2wd/4wd(just need ds bracket for 4wd, cross members are the same), 83-90 bronco II 2wd/4wd same as exploder
Actually you very specifically want a crossmember off of an '89-up.
The difference is the location of the holes for mounting the clips that
the fuel lines run through.
AD
