rx7racerboy2003
- Dec 19, 2008
i got a grinding noise i believe its the brakes hiting the rotor. it only happens when turning though. i think i may have a bad hub that is letting the rotor come into contact with the rotor when more pressure is on the opposite wheel it happens more when i turn to the left. and its the passenger side making the noise. the hub is probably bad cause there is a little play. any other ideas? i just replaced the brakes and rotors so they are new and the brake pads were rounded at the top edge so the top is what is rubbing.
