Front end issue.. HELP
cctacp
Does anyone know how to fix my front end from a neg camber when i pull forward, to having a level alignment when i back up? what do i replace to fix this? 1996 ranger 4.0 4x4 ttb dana 35. thanks
What are you talking about? Go to a shop and have it checked.
Yeah, I'm not sure what you are getting at either.
How are you measuring camber? Are you aware that your front end will change it's angles a bit as you move rearward or forward.
As I understand it if your toe is off it'll pull the tires together or apart as you drive and change camber.
yes,incorrect toe will cause your tires to lean in and out when moving forwards are backwards,but to save yourself some headache(if your not very oriented with alignment issues),take it to a shop,i spent countless hours trying to get mine right,it is very frustrating,i finally took it to big ten tires for a lifetime alignment
