Front Drive Shaft to Transfer Case
sryan
Wabush NL Canada
there seems to be alot of play on the front drive shaft where it connects, i can shake it and it makes a knocking sound. I haven't taken anything apart yet but i was wondering is there a needle bearing or anything that is easly replaced in the transfer case? the four wheel drive still works strong.
any advise would be great.
Shawn
are you sure its not the u joint
it may be the drive shaft yoke. grab one from the junk yard and see if that helps
Could be play in the ujoint, the yoke, or even the pinion.
dont think it's the pinion because the 4 wheel drive still works strong
You can still have play in the pinion assembly and it will still function normally. Especially if it's just a bearing going out.
ahh. ok........ well im going to haul it all apart today and have a look i'll post my findings
