94redranger
- Aug 15, 2007
- Age
- 35
I had a grinding noise in my front axle when I stepped on the accelerator and when I let off it the noise went away. Also when I turned corners there was a really bad clunking noise. So I replaced one u joint that had all of its needle bearings gone and checked everything else even pulled the right shaft out and inspected the carrier. Put it back together same noise and same clunking when turning corners. One questionable parts is the slip yolk, I am able to wiggle it around with my hand could that be a problem? Any help is appreciated thanks.
