- Aug 6, 2007
- Age
- 37
- Plattsburgh, NY
1999
so my pop has a 93 explorer sport that iam working on. i just recently freshened up an axle out of a 96 explorer for it.. i re welded spring perches on top of the axle as i did this when i swapped this axle into my ranger.. i noticed that in order to get the drive shaft aligned on the axle i had to angle the pinion up a bit in order to get it even with the drive shaft.. does this sound about right? i first set it like i did my ranger an no way would it have worked.. u joint was a a sever angle. other thing that i noticed, what did you guys do about shocks and sway bar? i thought the stock shocks would work but they are WAY to long so i ended up cutting sway bar off an relocated the bottom of the shock to the upper sway bar hole..
