rngrdngr
so my buddy cracked is frame from off roading. my idea to repair is to stop drill the 3 splinter cracks, grind a V into the cracks, fill them with welds, grind the welds flat. next would be to cut a 1/4" steel plate matching the frames curves, mark the shock mount holes, drilling them then weld the plate to the frame. last would be to install the shock mount with torque bolts or use some of my aircraft shear rivets. what do you guys think? anything i should do or anything i shouldn't do? thanks
