YAH YAH. I just wanna know what i can do to find a known good EEC for the Rat. A '94 4.0L 5spd ? Just a spare. On the help my BMW won't start page, there is a block diagram of if this/do this stuff. Testing the ECU is the last block. 35 yrs down the road, they should be moved higher up on the page. The early ECUs were prone to loose solder connections on the power transistor. 3 dabs of solder. The Bosch Motronic EFI is very similar to the '94 Ford stuff . The Bosch is a very robust system with very little tuning needed. This is the Bosch of 30 yrs ago. Today, not so much. In 21 yrs of owning 3 '88 528es, I've had only 1 failure. How long do old Ford EECs last? TIA
For
