Ford ranger 1999 4.0 OHV 4x4 transmission swap.I used a 2001 Ranger SOHC 4.0 4x4 transmission in my 1999 Ranger, everything worked perfectly except the new transmission has two speed sensors, the original only has one. The original wiring on my Ranger only lets me connect to one of the speed sensors. I did a test and the transmission does not shift properly and does not go over 30 mph. I tried disconnecting the speed sensor, tested it again, now it does not shift into any gear unless I do it manually. Also, the OD light is flashing. Please, if someone could guide me, I would appreciate it.
