Ford rAnger 1990 4.0l cold air intake
alonsito0114
I was wondering if I could put an cold intake I been searching online can't find one for it any ideas plz. Help
In the strictest possible sense you already have a cold air intake system from the factory. The factory duct work runs down and pulls air from behind the grille. This is a true cold air setup, because the stuff coming in is from outside the engine bay.
The aftermarket units that are marketed as "cold air" systems are actually "hot air" systems, unless you drop the extra couple hundred to buy the insulator box as well, but those are sold separately.
So if you are after genuine cold air, don't touch anything. If you are after the flashy look of the K&N or Airaid setup, then yes, there is probably one that will fit your truck.
What he said+! I am constantly amazed at how many folks actually THINK Ford & Chevy didn't know how to get the best power and mileage out of their air intakes. For some reason they seem to think a guy in a rented shop has it all figured out, and spend money with him to make their engines run WORSE!
P T Barnum once said "their is a sucker born every minute"!
Big Jim
