lilfordrunner
- Nov 12, 2011
I am all but finished with my 2.9 to 4.0 swap in the ranger. Took it out for the maiden voyage today. The idle is high (around 2k) and its running RIIIIIICH.
After doing some research here and on other forums I think it comes down to the MAF.
If the MAF Sensor and MAF return wires are hooked up backwards will that prevent the voltage from dropping when ignition is turned on? In the chiltons book, it says the voltage should drop (can't remember the exact readings) when the key is in the on position.
