4.11 ring and pinion seti, but it says for jeep/dodge/ford. i didnt even know dodge made a d35? or is this just like some other items just a bunch of random makes in the name? id like to know if it'd fit mine
Pretty sure you need reverse cut for a ranger, and jeeps are regular cut.... not 100% on jeep stuff though. lockers and stuff usually work though, aussie lockers at least has the same part # for ranger d35's as '88-94 jeep d35s
thanks dude, if they have the same spline count i assume the lockers would be the same. that ring & pinoin set confuses me though, i wish theyd say what its really for
Dodge owns jeep or use to. So Im sure tehre is a dakota or something out there that ran the D35. THe 98 newer ranger run a conventional cut gear, that will match up with the older dana 35s from jeep I believe. You just have to read the forums and find a good writup. I would check the tech articles too. When in doubt, go to TRSfabandoffroad Nitro gears are pretty cheap in 4.56
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
