Wanted For 2008 Extended Cab: 60/40 Seats, Fuel Tank, Tail Lights, Skid Plate (SF Bay/Northern Cal.)
knuckledragger
Forum Member
Oaktown
CA - USA
Vehicle
Drive
2WD
2.3 (4 Cylinder)
For 2008 Extended Cab...
Due to severe misadventure culminating in some theft and rogue dismantling...
We're in bad need of following parts...
  • 60/40 seats, preferably in really good shape (ours were in great shape, after trying to find good replacements I understand why ours were stolen).
    Ours is an extended cab but I think it's true that seats from a standard cab will work if I put 'em on the tracks from an extended cab? I think any year from 2004-2011 is the same.
  • Fuel tank, ours got torn up and has an excellent bunch of holes in it
    AFAIK any year from 2004-2011 will work fine so long as it's from an extended cab 126" wheelbase because standard cab tank isn't the same
  • Tail Lights, passenger side one was stolen, the driver's side one smacked up bad
    Again AFAIK any year from 2004-2011 will work fine, and AFAIK lights from standard cab are the same as from extended cab
  • Skid Plate: Had a nice one, now it's a goner
    Here too AFAIK any year from 2004-2011 will work fine but I'm pretty sure it it must be from standard cab, and I think maybe after 2008 they changed the mounting setup/brackets for the ext cab skid plate? At least I think I've seen 2 different stock setups for extended cab skid plates. So whatever Gen V skid plate you might have, it'd be great if I could also get whatever mounting hardware goes with it.
I'm in Oakland Calif. Close by would be wonderful but if not we can get the parts transported if not cost-prohibitive.
Thanks in advance for your help.
KD
