MorganMcCann
I bought a roll of LED strips on amazon, and I've been seeing a bunch of different things about which wire to splice into to get the lights to turn on with the overhead light when you roll the dimmer switch and when you open the door. Which wire is it?
Also which relay should I use if I wanted to have it set up so they would turn on with the door being open and a manual override switch?
She's a 1999 Off road edition Ranger with a 3.0
Thanks!
Thanks!
