Fog Light Reflectors Refurbish?
bruker
Western, Ohio
The reflector part of the fog light assemblies on my truck are in extremely bad shape. The reflective coating is flaking of in big chunks. I'm thinking of completely removing the reflective material and spraying them with chrome like paint. Has anyone here ever used that stuff and do you think it will work?
I don't think you will be able to get the surface good enough to make the paint effective. Best bet would be the metal tape they use for duct work, I've used that stuff with acceptable results.
they have chrome looking stuff for r/c cars but the stuff is not cheap and you might be better off just getting them from a junkyard!!!
My 99 Trans Am was being a huge PITA with the factory running light/turn signal lenses. They would crack. they were only 30 dollars a piece, so I replaced them once and they lasted a year... So after that I went to the hardware store and bought some Lexan, removed the lenses from the car and then using a hacksaw, very carefully sawed the lense off the housing. I pitched the lenses, and sanded the housing flat where I sawed off the lens. The reflector looked nasty, so I went to wash it, and the silver washed off!! So I went and bought some really shiney crome looking model spray paint (krylon chrome looks more like silver) and painted the reflectors with it. I used the housing to trace onto the Lexan, and cut it out with a jigsaw, and sanded the edges smooth, removed the film and glued them in place with a thin bead of clear silicone. Took me a couple hours to do both. They looked sharp, worked well, and held up much, much better than the OE. I wish I took pictures of it to show... So yes, I would say give it a try.
New fogs are only about $30 a piece from certifit.
Reviving an old thread here but back in May I tried some Rustoleum Chrome paint in the foglight reflectors and it's holding up great!
cool! Glad your fogs received new life!
