ArizonaRanger
I've got a 91 Ranger: 2.9 with the FM146 Transmission.
I was driving down the freeway in 5th, when something went wrong. I'm not exactly sure what, but it felt like the truck kicked itself out of gear and into neutral. I pressed on the clutch, and it went straight to the floor with no resistance. I pulled the shifter out of the 5th gear slot, and coasted to the shoulder to call a tow. After a while of waiting, I tried the clutch again, and it seemed to have pressure now, giving a normal amount of resistance, but the shifter won't go into any gears, even with the clutch all the way down.
My first thought was a problem with the hydraulics. I checked the fluid a couple of weeks ago and it looked fine, but I'm going out to check again.
Has anyone had a similar problem, or perhaps knows what it might be. I'm willing to do my own work on it, as long as I know what I'm trying to achieve.
Thanks
Thanks
