FM145 FM146 FM132 - 5 Speed Strengthening Pans - Price Drop!
plh
Wisconsin, USA
We have a steady supply of Strengthening Pans available. Made in thicknesses of 19mm (3/4") for $109.95 or 12mm (1/2") for $94.95. Includes mounting hardware, Loctite etc.
Price Drop: The 12mm Tuff Pan Pro Kit is now $89.95
We also have a specially tooled TuffPan for the FORD applications.
Check Here: http://www.tuffpans.com
whats the point of that?:icon_rofl:
Ostensibly it is used to reinforce the exterior of a trans with weak internals, for the purpose of off roading.
...Offroading?
who goes rock crawling with the intention of bouncing there fm146 off rocks though? lol....
itd be different if the trans factory dropped down below the crossmember/frame and all that
For the purpose of keeping your transmission for blowing apart. Improves the torque handling ability by strengthening the transmission case. These transmissions are known stock to have problems with the torque loading between the main shaft and secondary shaft. Stock - as torque is applied the case flexes and spreads the 2 shafts apart - moving the torque carrying to the weaker part of the gear teeth, then they break. These rigid pans and gasketing method stiffen the assembly. Several people are running 400+ hp and 400+ ft/lbs torque through these now with the TuffPan without problems.
