Flywheel bolts won't break loose...
96firephoenix
Indianapolis, IN
Changing the clutch at 214K... can't get the flywheel bolts loose.
My impact gun (old, and maybe not working at 100%) is rated something like 240 ft-lb, and a breaker bar just turns the engine...
Halp?
A wrench and a hammer. or a socket and bar on the front crank bolt.
^^^ Yep, I like the idea in the picture, post #14.
I guess for someone doing such work allot .. something like this is pretty handy. Although I don't know that stout enough to back up a the forces of a breaker bar on the bolts which usually means means to break the bolt heads off not break them loose.... :headbang:
Use your BFH! Give em a WHACK. Here's what is going on. The bolt is STRETCHED in it's path thru the flywheel. Giving them a whack will loosen the stretch and allow the threads to be unscrewed.
I have used this method lots of times.
Big Jim
One only needs two pressure plate bolts and a long length of steel (crow bar/angle iron) the prevent the flywheel from turning. The ACVW guys have a pre drilled metal plate that fits brake drums/flywheels in an inexpensive multi tool.
http://www2.cip1.com/ProductDetails.asp?ProductCode=C26-000-145
A hammer? I find flywheel bolts in crankshafts don't benefit from that.
sooo..... I'm an idiot... turns out that since I bought my air wrench used, and no instruction manual, I didn't know the tricks of using it...
Long story short, Max power tighten is Min power remove.
