Fluid leaking from exhaust manifold & exhaust
squid267
Dallas, TX
2.9 V6
Hey y'all
Bought a 87 Ford Bronco II as a project car back in October. It started leaking fluid from the exhaust manifold and the exhaust. I'm having a tough time determine if it's fuel leaking or if somehow coolant is getting in. It definitely smells like gasoline but when I touch it seems like it could also be coolant. Here's a video I took. I'm hoping identifying the leak might help my figure what the fix is. I'm hoping it's not a blown head!
squid,
Gasoline would ignite if it were passing your exhaust manifold, so I dare say it's not fuel. It's coolant.
Could be a number of things, the 1st that comes to mind is that those exhaust manifold deteriorate and can contribute to coolant leaking. Could also be the head gasket or a damaged head.
That is a lot of something.
Are you losing coolant? What does your oil look lile?
Its a 2.9.
More then likely its a cracked head. Pull the dipstick, see how the oil looks.
