fluid ammounts
Ranger4657
Solid Axle Swap
Loveland Colorado
need to know the ammount of oil needed for:
gear oil for front dana 35 & rear for the 8.8
and ammount for a 1354 manual Tcase
you can move this thread if you want
thanks!
The 8.8 takes 5 pints (2 1/2 32 fl oz. bottles) IIRC. I can't remember how much the front takes... Any parts store should be able to tell you.
ive never dained the front before, anyone have any good methods?
Drill a hole and then make a drain plug or use a suction gun. Or pull the pig, that's always fun.
Haynes says
Haynes says 3.5 pints front axle
2.5 pints xfer case.
I did both recently on my 1996.
I use a 3/8 inch hose, bent 3/8 steel tube (toilet water line), some PVC ppe with adapters and a shop vac.
I built the contraption because my rigs always end up in muddy water and with worn axle shafts and seals, water gets in.
a complete list...
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1473032
