Floor Pan Rust...
Sham66
Howdy!
Got some rust under the driver seat. It's an '86 Ranger. Are there any floor pans or panels available?
My plan is to fix that and then replace the front seats.
Thanks!
James
Depending on how bad your rust issue really is there could be easier ways around replacing the floor pans. Is there holes yet?
both patching and replacing are options available to you...but make sure you check the firewall for rust before you replace the floor pans...usually a leak from around the windshield indicates other problems that should be taken care of before the floor pans...
