Flood
Sclove69
Hello my ranger friends . I have a 87 ranger wit a 2.3 liter automatic .its runs good for about a few mins then all of a sudden it starts to flood for about 2 mins then it goes back to running normal .what could it be ?
2.3 with FI shouldn't be flooding...unless you have the 2.0 with a carb...
Flooding on a FI model would mean your spark is off or not working properly on one of the cylinders...so could be a faulty wire, distributor, or plug...or the computer is wonky
Put a timing light on each of the plug wires while it runs...if one of the wires doesn't light up for any length of time then that is your misfire...
I'll try that and I'll let u know the out come and by the way it's FI
Could also be an injector is sticking open.
You can use a small hose and listen to each injector while engine idles, should have a steady "tick, tick, tick"
Also, on the fuel rail there will be a Fuel Pressure regulator(FPR).
This is a valve controlled by the vacuum from the intake.
If the diaphragm inside the FPR gets a leak, then that vacuum hose sucks raw fuel into the intake, causing engine to flood.
So remove this vacuum line and check it for fuel or fuel smell, if it smells like gas replace FPR.
Long shot but not 0 shot, lol
All EFI engines use an electronic version of a Choke.
This starts with the ECT sensor, it is a 2 wire sensor that looks similar to the 1 wire sender for the dash board temp gauge.
The ECT sensor tells the computer the coolant temperature, if cold the computer will run the injectors rich and will advance the timing, just like a carb choke did.
ECT sensors rarely fail, and usually they cause rough running when engine is cold or rich running(lower MPG) when engine is warm, never seen and intermittent ECT issue
