lukeburris53
- Dec 12, 2007
As the title says, I flipped my B2 (I'm fine, not a scratch). It was laying on the passenger side primarily, up against a tree with all 4 wheels clearing the ground. It was probably upside down for 30-45 minutes. I remember shutting it off, so it was still running once I was over, but probably not more than a 10-15 seconds.
It won't turn over now though. The next day, when I tried to start it, it seemed like the engine turned and then stopped, like it hit something. I put a new starter on it 4 days before. It didn't lose much oil, a quart at the very most. I have put the charger on the battery and it still wouldn't go. I had to leave to come to college, but my brother and grandpa have tried to pull start it with a tractor, but the wheels just slid.
A mechanic friend thinks that oil may have slipped past the rings or something and fill the cylinder(s), which won't compress with that in there. They plan to pull the spark plugs and try it. Is that a possibility?
I wouldn't think the main bearings would burn up in just a few seconds, as it was still running until I turned the key off. What else could it be? Thanks..
