tylerb826
well after studyin the axle flip kit i decided that since money was tight and i couldnt buy one i would jus have one made...its simple enough. my buddy made the brackets out of 4x4 1inch steel tubing..some heavy duty sh*t..lol..he made it exactly as the ones you would buy even with the offset hole....the hole wasnt that great but we were goin from scatch....we put them on and everything went ok but now the truck sits way lower than expected..it is on the frame....i mean its slammed out...and i feel these wierd vibrations and the transmission it makin some noise in the higher speeds...im gonna change it..but wat could cause this..and i think the angle of the rear end is off a bit..it points upward and causes the drive shaft to look like its in a bind perhaps..im not sure how to explain it..ill take a pic later if i can....any help would be appreciated
thanks
thanks
