motcher41
- May 22, 2016
- Automatic
So back when I bought my 92 Ranger 2.9 V6 & A4LD the flexplate center cracked through and separated from the outer portion that is connected to the Torque Converter. When we replaced the flexplate we had found the bell housing bolts were VERY loose and attributed that to causing the flexplate to break. 10-20k miles later give or take the same thing happened. I don't know if the first one was stock or aftermarket but the one I installed was aftermarket. Bell housing was nice and snug this time around but the spacer has a broken collar on it. Torque Converter was tight to the flexplate as well.
Think that would cause it to flex enough to crack or are the aftermarket flexplates just that crappy?
Can't locate a decent priced M5R1 so probably going to put the auto back in.
Sent from my Nexus 6 using Tapatalk
