A flex fan wouldn't cool my V8......it overheaed at every stoplight.....
You need at least 2,000 cfm blowing thru the radiator to keep stuff cool...
trust me...i am a doorgunner
FYI.......................
2" pitch fan blades/12" diameter shroud/1000 rpm electric motor
3.14 times radius squared
3.14 times 36 equals approx. 108 square inches
2" pitch at 1 revolution equals 2 times 108 equals 216 cubic inches in 1 revolution (Pitch: the distance of the fan blade from the leading edge to the trailing edge)
an e-fan that runs at 1000 rpm times 216 cubic inches would put out 216,000 cubic inches of air
216,000 cubic inches divided by 144(standard number) equals 1,500 c.f.m.
so......a 12"diameter e-fan that runs at 1,000 rpm puts out 1,500 c.f.m.
OR you can plug in the numbers below of the fan that you find at the junkyard to see how much output it has:
radius of fan blade Squared________" X 3.14 equals Square inches of fan surface ________" X fan pitch _____" equals airflow at 1 rpm ______ X rpm of electric motor _______ divided by 144 equals output of fan in C.F.M. _______
I learned that from Google
